Author Topic: Some links for UK modellers  (Read 5904 times)
Re: Some links for UK modellers
« Reply #15 on: November 12, 2013, 08:15:59 pm »
Magnet wire is really small wire that has an enamel coating as insulation.
It is normally used for coil windings in electromagnets and transformers.
Offline Tony Westwood
« Reply #16 on: November 13, 2013, 02:11:12 am »
Cool, thanks for explaining that for me.
Looks like I'll need to get some of that too then  ;D
« Reply #17 on: November 13, 2013, 02:28:18 am »
I've been trawling for LED strips and found these links on Amazon, are they any good?
http://www.amazon.co.uk/Lighting-EVER-Strips-Cabinet-16-4ft/dp/B004JRNNKY/ref=aag_m_pw_dp?ie=UTF8&m=A2KTHBZ9SBGV6S
http://www.amazon.co.uk/Lighting-Flexible-Waterproof-Ultimate-Backlight/dp/B0085UPUDE/ref=aag_m_pw_dp?ie=UTF8&m=A2KTHBZ9SBGV6S
I don't really know what I'm looking at with electronics yet, they do look the same as the ones Boyd uses, but it just says high brightness SMD and I'm sure Boyd said his were "Double Density".
Tony
« Reply #18 on: November 13, 2013, 08:54:15 pm »
Checked out your links. Those are the right led strips. They are what I use.
They are single density but work fine. Double density packs more leds in less
length. Single = 3 to a 3 inch section, Double = 6 to a 3 inch section.
Hope that helps.
« Reply #19 on: November 14, 2013, 12:11:06 pm »
Yep, that helps loads.
Thanks Tankton
Offline billski
  • Jolan'tru
    • YouTube channel
« Last Edit: November 14, 2013, 02:07:15 pm by billski »
Offline Firebiro
« Reply #21 on: November 15, 2013, 03:22:21 am »
5M???? That's epic!!!!! They look double density too, looks like they don't post to Ireland though, boo, ha ha have enough strips to keep me going for now though, but great find! Does the waterproof tape hinder in any way?
Morgan
Offline billski
  • Jolan'tru
    • YouTube channel
« Reply #22 on: November 15, 2013, 07:28:48 am »
You can non waterproof tape in 5M, I will have a look if a site ships to Ireland. I do prefer the non waterproof as it doesn't have the plastic top over the SMD's
Offline Firebiro
« Reply #23 on: November 15, 2013, 08:00:10 am »
Must look again, its one hell of a price! yeah the non waterproof would take less room in the model also!
Morgan
« Reply #24 on: November 15, 2013, 11:56:21 am »
Once you pick the options on screen the price changes to
Offline luminous
« Reply #25 on: December 02, 2013, 07:52:53 am »
« Reply #26 on: December 07, 2013, 09:00:27 am »
hi guys,
As you are probably aware, no-one seems to stock Testers decal sealer here in UK, so we've either got to pay more in shipping than we've paid for the item from USA or take a gamble on the minefield of "Acrylic Lacquer" products here in UK and hope that they are not in fact Cellulose based items that will dissolve your decals (Halfords clear lacquer is a good example of this).
After trawling through Google most of the morning I finally found a proper acrylic decal sealer here in UK. It's called KEEN TOP CRYSTAL CLEAR SPRAY and it specifically states in the product description that it is "PERFECT" for sealing inkjet water slide decals.
Here's the link just in case anyone else wants some for their Acreation decals....
 http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=2&cad=rja&ved=0CD4QFjAB&url=http%3A%2F%2Fwww.craftycomputerpaper.co.uk%2F.-Acrylic-Spray-UK-SALES-ONLY_SPRAY-ACRYLIC.htm&ei=xDOjUp2pO4Gp7AbUoIC4Bw&usg=AFQjCNF3oYC8kwntS0yQaTcpu1GiSRZ1Jg
Hope this helps,
Tony
Offline AlistairBiggs
« Reply #27 on: March 13, 2014, 01:26:19 pm »
Good link Tony thanks :)
To boldly go... Wait a minute who forgot to replace the Dilithium crystals...
« Reply #28 on: March 13, 2014, 03:10:57 pm »
Many thanks for the links Tony - these will be getting used in the future! ;)
Offline billski
  • Jolan'tru
    • YouTube channel
« Reply #29 on: March 13, 2014, 05:46:08 pm »
Thats great Tony. Fantastic find
