Author Topic: ST:TMP Drydock (WIP)  (Read 23699 times)
Offline NemVia
    • NemVia.net
« on: November 05, 2013, 05:20:02 pm »
Hi Everyone!
I've been working on this build-up for a little over 2 years now and am currently building the second phase of the project which is the Drydock from the Motion Picture. The first part of this project was building the Enterprise model. This is the DeBoers version of the Enterprise. About 45" in length. The larger scale is a lot easier to detail, but because of the resin used to make the model it can be a little harder to assemble. Adding to the complexity of this project is the way the Enterprise will be mounted into the Drydock so that it will appear to be floating in there without a model stand or wires to hold the model in place. I built a 1/350 scale PLE version of this and it turned out fairly good, but this new project will be needing some heavy duty reinforcement to support the weight of these 2 giant models. I usually don't post too many pics to my threads but I leave a link to view my progress for each month. It's just a little quicker for me and saves a lot of time. Most postings are done about once a month. This month of course will be the November Updates page on my personal site. Here is what I have for this month:
Hi everyone!
I apologize for the long intervals between updates, but for October all I did was a lot of drilling and aligning and drilling and aligning and..... well, you get the point. So, I thought I would wait an extra month so you can at least see some progress with the dock.
Because using metal in model construction is not a forgiving as with plastics, one has to be more precise with the drilling and bending of tubing and other pieces, so yes, it does take a little longer to get things done, but I'll tell you, in this case at least it will be worth the wait.
In this month's update I've finally been able to test fit some of the panel frames with the main modules. As I said In other updates I needed to wait for some parts to come that were back ordered. The back ordering occurs because of the quantity of items that I need for these projects. I've had to order 164 copper tubes, about 56 or so threaded rods and a couple hundred dome and regular nuts and so forth. I've had to cut a lot of these items to length and make sure they fir properly into their respective pieces. This is definitely a take-your-time and do-it-right-the-first-time projects(s).
Other than the panels frames, there will be very little to solder together. Following the design of ST:TMP filming miniature there will be a lot of screws, nuts and bolts holding this baby together. If you watch all of the drydock scenes including the Enterprise leaves drydock you will see a lot of these details right on the screen.
But anyway, this isn't a just drill it and put it together project.  This updates I've started by adding the anchor cone pieces to the outside parts of the overhead module, then I have to take each panel frame individually make sure that each of the holes both on the module side as well as on the side and bottom frames will line up. I've started on the top tier of frames on only one of the module pieces. Now that I know what to do I can get the other tiers lined up and in place. With all of the threaded rods and dome nuts in place I was very pleased to find that the panel frames are able to support their own weight so when all of the pieces are finally in place I will not need additional supporting rods to hold everything up as I did with the 1/350 PLE drydock. This is also something that TMP dock was able to do.
All the pics in this month's update are pretty much test-fitting pictures to make sure everything lines up correctly. I will not be able to permanently weld everything together until I can get the wiring in place for the light panels and other effects. There are 19 new pics in the November Updates tabBy next update I hope to have the tiers finished on at least one of the modules. We'll see how it goes. I will try to get as much done as possible in the next month because December is a very bad month for me secular jobwise, so I hope you enjoy the new progress pics and hope to hear from you. All comments positive and negative are welcome!
Feel free to sign up as a member and be the first to receive notice of any updates on my site.
Talk to you next month! Take care and Happy Modeling!
http://www.NemVia.com
www.NemVia.net
Offline NemVia
    • NemVia.net
Re:1/260 Scale ST:TMP Drydock (WIP)
« Reply #1 on: November 28, 2013, 09:03:09 pm »
December Updates
Well, here we are! Another month goes by and we are already into December.
I have 10 new pics for your viewing the DECEMBER UPDATES - 2013 page on the left sidebar menu on my site. I've spent the good majority of November working just on the panel frames. The hole alignments have to be pretty precise so it takes quite a bit of time to get everything just right. For each of the sides, both port and starboard, I could only fully assemble five panel frames each with all three tiers. The reason being that the last to panels on the fronts and rears of each side on all three tiers need to be left unsoldered together so that I can thread the lighting effects through the end sections and through the tubing of each tier and to each light panel.
Did you get all of that? Well, if you didn't just wait for the wiring update and you'll see what I'm talking about. But so far, everything is fitting in place and all of the tiers seem very sturdy and will be able to support their own weight as they will be freely hanging from the sides of the overhead module. There should be no supporting rods like I needed with the 1/350 drydock model for this build.
In other news, which in this case is GOOD news, I was able to get the Drydock's steel frames back from the welder this week. They are built very similar to the 1/350 scale version except that I am not using copper piping. These frames are made from steel to support the weight of both the dock and the DeBoers Model. I will now be making the necessary holes in the overhead modules to anchor them to the steel frame. After this is done I will be drilling out all of the holes needed in the support frame to bolt the modules to it as well as holes for casters that will be used to move this large model around to be worked on. I have made this frame so that the lower section or Dolly can be removed so the model can be hung on a wall of my client so desires. Anyway, after the holes are all drilled out I will be sanding the entire frame(s) down and spraying the entire assembly with Rustoleum to prevent any more oxidation on the metal.
December is usually an unfruitful month for me as far as work on the models goes. Our company gets quite overwhelmed with work during this month, so the January update might be a little lean with pictures, but we'll see how everything goes. Well, that's my update for this month!
Hope everyone enjoys the pics! As always, be safe and happy modeling and I will see you in January! Take care,
Mark.
« Last Edit: August 02, 2014, 03:22:15 pm by NemVia »
www.NemVia.net
Offline NemVia
    • NemVia.net
Re: ST:TMP Drydock (WIP)
« Reply #2 on: January 04, 2014, 11:28:34 am »
Hey! Been busy this month But should be able to resume work on the dock. Just minor updates on my site. Give me a few more weeks and I'll have some new pics!
Thanks, Mark
www.NemVia.net
Offline NemVia
    • NemVia.net
« Reply #3 on: January 30, 2014, 05:53:35 pm »
For the 1/260 Drydock Updates, I have added the latest progress pics in the February updates page. I've been able to sand down the steel frames to prepare them for spraying. They will be sprayed Flat Black to hide the fact that they are supporting the models. I put a couple of pics to show how the frame can be mounted to a wall for display. For the rest of this month's update I had to cut holes into the overhead module side panels to allow the support tubes to slide through. Then I was able to bolt the module frames to the tubes so they are now permanently anchored to the frame. I've also started adding the anchor cone pieces to the center sections of the modules. These have to be done one at a time to make sure the anchors line up with the holes on the modules. There are 70 of these total on each of the Drydocks.
 I've also ordered some Dry-Transfer Lettering that will later be used to mark all of the light panels according to ST:TMP flyby scene. During the month of February I will be drilling the tension rod holes for all of the light panels and their frames and then mounting all of the panel frames to the Port side or rear Modules. If I can get all of this in place I will be able to start threading the EL Wire for the lighting effects. Take care for now and I'll see you next month!
 Mark
www.NemVia.net
Offline NemVia
    • NemVia.net
« Reply #4 on: February 01, 2014, 01:25:50 pm »
 Mark
www.NemVia.net
« Reply #5 on: February 06, 2014, 12:44:30 pm »
Will be cool when you are finished.
Offline NemVia
    • NemVia.net
« Reply #6 on: February 26, 2014, 08:21:27 pm »
March Updates 2014
Hi everyone! It's been a very very cold winter here in Illinois this year and unfortunately that is putting me behind on my drydock build a bit. Most of my shop is in my garage and it is extremely difficult to work on certain things when its 0 deg. or colder out there. But I've managed to do some smaller work on the project and was able to get some things done.
In this update I have had a change in some of the detailing work that needs to be done on one of the docks. It was requested that I put some more detail into parts of the dock specifically around the light panels and panel frames. My client wants some turnbuckles added to the panels as was seen in one of the close up models in ST:TMP. So I've ordered s few special tools that I do not have, such as a small pen sized screwdriver and a pin vise adjustable chuck so that I can drill out some 700+ holes in the panel frames and light panels using a 1mm drill bit.  This is so I can add some turnbuckle anchors for the tension rods. These will all be connected to the light panels and there frames vial the rods and some very tine screws and nuts. I think  I'm also going to need a larger magnifying glass as well.
In the March updates I have pics of how I did this. It takes a lot more time whereas the 1/350 model I just drilled the holes into the frames and panels and then cemented the tension rods into place and then I was done. Not so easy this time but I think it will be worth the effort.
I've also been busy reviewing specific details that need to be done by viewing the drydock scene in ST:TMP. One thing that I really noticed this time is that there are 2 different colors seen on all of the light panels. When they filmed the miniature they used a lot of lighting to get the shots they needed and that appears to have washed out the color differences on the panels to a certain degree. Comparing what's on the screen to Adam Schneider's refurbished Drydock model It's easier to see the differences now and what I need to do. So the panels will need to be sprayed no less than 2 different colors. I've been ordering the paints that I need for this part of the job. There is also a tremendous amount of detail between each of the panel frames and just about all sides of each of the frames, so I will be making mold masters of specific details so I can add them in before I start spraying the entire model.
The dry transfers I ordered have some in so when I finish the panels I can start adding on their specific numbers.
I've been asked where I get some of my material for the detailing of this model. I have a lot of reference materials including pictures of the actual miniature and over the years I have found some very rare behind the scenes photos from when they filmed the movie. I've included those in the March update Page for those of you who are interested.  Well that's it for now.  See you next month.
Mark
www.NemVia.net
Offline NemVia
    • NemVia.net
« Reply #7 on: March 29, 2014, 09:23:57 pm »
This month I have been able to get somewhat back on track. The weather has warmed up enough for me to go back into my garage to do some of the necessary work that can't be done inside our house.
 I have 23 New Pics in the April Updates. Here are the details:
 I have finally received the armatures for the models that will be used to marry the Enterprise models to the docks. They are made of 1/4" hollow tube and are quite sturdy. I had them welded together in a specific manner so that they will be hidden as best as possible inside the dock and the ship giving the illusion that the ship is floating inside the dock.
 All of the copper tubes that I cut the holes into have been placed inside the panel frames. These will be used to support the light panels as well as allow me to run the lighting effects through each of the tubes.
 I have also started painting the light panels their respective colors. This took about a week to do. I was able to finish those and start work on the dry-transfer numbers and letter that are on each of the panels. In ST:TMP the dock was heavily decaled only on the side that was visible on the screen. The side unseen or port side has decaling but not to the extent of what Row "E" of the panels has. As I have more time I will be adding more of the decals to each of the panels since this will be a full model of the dock. The bummer about the dry-transfers is that they only give you so much of certain letters and/or numbers. For instance many of the panels are numbered in the 30's and 70's. Guess which numbers they give you the least amount of? Yeh... 3's and 7's so I have to order many many sheets of the transfers and then try to use the other numbers just so I don't waste too many of the decals. But.... hey.... that's the life of a model builder, huh? Anyway I think Row "E" which is seen on the screen turned out rather nice.
 Now, another feature of the Light panels is seen on the upper right and left side of each of the panels. Since I don't know what they really are I am going to call them the power nodules for the light panels. I used reference pictures from the movie as well as some pics I shot of the Filming Miniature to scratch build a highly detailed master so that I can cast all of these pieces rather than build them all individually. Just a side note, it took me about 4 hours total to create just one of these from scratch. The only thing left that I need to do for these pieces is build the 2 tanks or bottles that are seen on the top and bottom of the light panel support poles. These will be cast separate from the nodule pieces as well as a clamp-like piece that connects these nodules to the light panels. I should have them done by the next update.
 Last but not least I am taking some new measurements for some interior sections of the dock can be seen from the outside. I am going to do what I did for my 1/350 scale dock and that is add a large interior Hanger bay that can be seen by looking into the Aft End of the dock though the hanger doors. I have a lot more room to work with on this dock and I purposely made the support frame so this dock can be a lot larger than the 1/350 version. You will be able to see many Shuttles, work bees, Shuttle pods, cargo containers and other details. This should help give a great depth of scale to the model and how large it would be in real life.
 Hopefully by next month's update I will have some of the panel frames painted up and ready to be connected to the Overhead modules. Hopefully there will be no Hang-ups or snags. The weather is getting better, slowly but surely. This will make things go a lot faster. 'Til then, see you next month!
 Mark
www.NemVia.net
Offline NemVia
    • NemVia.net
« Reply #8 on: May 01, 2014, 05:18:44 am »
Hey Everyone!
 This month I've spent quite a bit of time casting many different pieces for the Light Panels as well the panel frames. The focus was mainly on the Power Nodules that are seen on either side of the tops of each of the side light panels. I needed to cast these parts in two different pieces because of the complexity of each part. There are 84 nodules on each of the docks so I had to cast 84 nodules as well as 84 of the clamp pieces.
 There are also 2 tanks that are on each of the nodules that I needed to build from scratch. There are 168 of these needed per dock, so I made castings of those and painted some of them light gray. The end pieces on all of the tanks will be hand painted neutral gray. When the Nodules are finally painted I can then cement all of the tanks to the Nodules. Whew! A lot of work in the coming months.
 Other parts that needed to be cast were the box like recesses that are seen underneath the overhead modules. There are 7 per module. They were challenging for me to cast because of how thin the walls are. Added to that was also a slit on the front and back parts of these pieces that are used for allowing light to shine through for additional effects. I never knew these slits were on the model until I was able to see the Drydock Miniature in person. Be assured they are there, they just never had any screen-time in the movie.
 In other updates you should know that despite all of the obvious details seen on the Overhead modules there is also an abundant amount of details that follow the inside and outside parts of all of the framework for the side panel frames. I made up 8 different versions of the detailing and made molds of them. Now when I add them as details to the dock I can use them at random and also flip them upside down so they will appear as even more details. These will be used for the horizontal parts of the framework. I also made up 3 additional detail pieces for the vertical parts of the framework which also can be flipped over for different details. I found it was faster to use more that enough resin so that I can pull all of these pieces out of the mold at the same time, then use a belt sander to get rid of all of the excess resin and thin out the strips. You'll see what I mean in the May Updates page.
 I have been able to apply the horizontal strips of details to the panel frames where the anchors hold the frames together. Eventually I will be able to start painting the frames and assembling them to the modules.
 In The last week or so I have started painting the Power nodules. I applied the first color which is Intermediate blue and I've started masking off the nodules to add the second color which will be Rust. Later I will hand paint some of the smaller details with a small brush. I was hoping to get at least one of these done for this month's update but I just couldn't get that much done. Sorry! I tried. When I get one of them painted up I'll post ASAP. And last but not least I've begun casting pieces for the hanger bay for the overhead module. I'll have some pics for that next update. There are 25 new pics in the May Updates page! Enjoy! and I'll see you next month!
 Mark
www.NemVia.net
Offline SJM
  • The KitBase
    • Scott's Model Gallery
« Reply #9 on: May 01, 2014, 08:30:00 pm »
You deserve more replies...because your work is outstanding!!
Offline TrekWars
  • Babby builder of SFMA
  • Refits make good night lights
« Reply #10 on: May 02, 2014, 06:00:03 am »
SJM I really couldn't agree more
Nemvia your The best Star Trek scratch builder on the forums from what I see there it's amazing
Anyone challenges that show me your thread because man what a build
Trekwars
Offline NemVia
    • NemVia.net
« Reply #11 on: May 31, 2014, 08:40:15 am »
Hello Fellow Model Builders!
 Although I don't have a lot of update pics for you this month, I have done I good chunk of painting details onto many, many pieces. The square box insert pieces for the overhead modules have been airbrushed to their final color and the lighting slits have been cut into each of these pieces. I have a good pic of one of these as a test fitting pic in the June Updates page.
 Another chunk of the work load for this month was hand painting some of the details for the Light Panel Power nodules. There are 4 different colors on each of these pieces now and there are 84 of these pieces for each drydock model that needed to be painted. I have also been hand painting some of the details on the end caps of the tanks that will later be cemented to the power nodules. IT's easier to cast them in groups of 4 and paint them while they are still on the sprue pieces. When they are finished I can just snap the tanks off and then cement them onto the nodules. I'll have some pics of that in next month's update.
 As long as I had my airbrush out I started to paint some of the vertical detail pieces for the light panel frames. I first had to sand down the back parts of these pieces so that they are now pliable enough and can now be curved with some amount of ease when they are put onto the panel frames.
 That's what I have been doing for the most part for this month. But I also figured out how many more of each of these pieces that I need to finish the model and have been doing a lot more resin casting. By next update I should have all of the needed pieces cast and then painted and THEN I can get to work assembling all of the parts.
 In the next month I will also be working on the hanger for the overhead modules. I know I started that a few updates back, but I really needed to concentrate on getting all of these detail parts cast and painted. You should start to see the beginnings of the work crane and work light modules and booms in the coming months.
 Thanks for being patient with this build. I know it's taking a while to get anywhere, but soon I can assemble everything and then we will start to see some awesome results. Keep checking for updates and I'll see you next month!
 Mark
www.NemVia.net
Offline NemVia
    • NemVia.net
« Reply #12 on: June 23, 2014, 03:10:47 pm »
Thanks Guys! Perhaps there is just not much interest  in the drydock anymore. But, it's always good to hear from any fans!
Glad to hear from you!
Mark
www.NemVia.net
Offline Artie
« Reply #13 on: June 23, 2014, 08:29:07 pm »
Yes I love your modelling skills and this project that your working on :) I wish I had the skills and time to build something like this.
I'm sorry I haven't responded with a response, however your work is outstanding and I look forward to more photos and updates on your progress.
I have noticed a lot of people do look at building threads, but few comment. ( maybe because people are busy ..?)
Sadly this is a fact on this forum. Please be patient with people, as I'm certain that they also feel as I do and enjoy your work....for me a DRY DOCK is of GREAT interest. :) So please don't be discouraged or think people aren't interested in your project...as Im sure the opposite is true. ;)
regards Artie
Offline AussieTrekkie
« Reply #14 on: June 23, 2014, 11:48:22 pm »
I'm impressed with your drydock.
I'm thinking I might build one from your photos for my Refit.
Scott.
