Author Topic: White LED Backlight Module  (Read 1347 times)
Offline frankjb2
« on: July 12, 2014, 01:44:03 pm »
I found these flat LED panels that will fit in tight spaces they come in 3 sizes
Small 12mm x 40mm
MEDIUM 23MM X 75MM
Large 45mm x 86mm
https://www.adafruit.com/products/1626
Offline Guns Akimbo
Re: White LED Backlight Module
« Reply #1 on: July 12, 2014, 01:45:52 pm »
I have some on the way.  ;D
Offline Xeek
    • Xeekworx Models
« Reply #2 on: July 12, 2014, 09:06:15 pm »
Thanks! I think this will solve my problem using a 5v system and needing to waste current just to up that to 12v for LED tape. Hopefully this will work just as good as LED tape but perhaps with a lot less current. I purchased 4, but maybe only 2 will do the job to light up the primary hull of whatever projects I have coming.
