Author Topic: Flashing machine gun effect kit  (Read 1748 times)
Offline WeeMoe
« on: April 05, 2015, 11:42:43 am »
Found this while searching google, it's a flashing machine gun effect board for re aircraft could be used in a viper or pulse phaser effect?
http://www.hobbyking.com/hobbyking/store/__38003__Dr_Mad_Thrust_Machine_Gun_Effect_LED_Unit.html
Re: Flashing machine gun effect kit
« Reply #1 on: April 05, 2015, 12:13:47 pm »
...could be used in a viper or pulse phaser effect?
That could work for model kits where you might want rapid-fire light effects.
However with that board, its input voltage is rated between 5-volts to 7.4-volts.  Many people tend to go with 9-volts or 12-volts for their model ligthing projects.  To use this board within a 9- or 12-volt environment, you'd have to get a DC-DC step-down converter board for it in order to avoid burning it out.
Offline WeeMoe
« Reply #2 on: April 06, 2015, 10:08:32 am »
Dam didn't think of that & I've already ordered 1! 😨 so I need to get that conveyor board and then I can use a 9volt battery or 12 volt power lead & it'll work
« Reply #3 on: April 06, 2015, 11:05:51 am »
WeeMoe,
Here's what I've used.  You can probably find something a bit cheaper (others might have more XP on this than I) - this one can supply up to 3 amps.  Might want to search ebay too:
UBEC DC/DC Step-Down (Buck) Converter - 5V @ 3A output
Offline WeeMoe
« Reply #5 on: April 08, 2015, 02:35:13 am »
Or could I get a 5volt power cable to plug into the wall at home?
http://www.kenable.co.uk/product_info.php?products_id=6027&gclid=CIDm2vuY5sQCFYrJtAod2lUAQg
