Author Topic: 1/32nd scale Corsair finished.  (Read 12681 times)
Offline trekker9211
  • Coming home
Re: Another Corsair! This time in 1/32nd scale
« Reply #30 on: August 23, 2015, 08:45:17 pm »
Hi Nick! As soon as it's just dry enough, I have an old cotton t-shirt I wrap around my index and middle fingers and SLIGHTLY moisten and go. Change positions on t-shirt often or you'll end up rubbing the wash around instead of removing it. 8)
Offline nkaltso
« Reply #31 on: August 23, 2015, 08:57:51 pm »
Thanks,  Ive used Game workshop and Valejo washes before.  They clean up a bit differently, but ill try the cotton shirt next.
The build is looking amazing from the kill tags to camp its a top notch job.
Nick
Offline trekker9211
  • Coming home
« Reply #32 on: August 23, 2015, 09:24:57 pm »
I've been really patient on this build and I'm liking the results. Still a little way to go, but I can see the light in the tunnel getting closer! I'll be watching your Enterprise B build. Thanks Nick. 8)
Offline trekker9211
  • Coming home
« Reply #33 on: August 24, 2015, 03:59:11 pm »
Pilot painted, permanently seated and starting on the chipping. The saga slowly continues... 8)
« Reply #34 on: August 24, 2015, 08:11:05 pm »
That looks terrific! The top photo it seems the pilot is smiling :)  He must like your work too.
Offline trekker9211
  • Coming home
« Reply #35 on: August 24, 2015, 08:35:17 pm »
LOL! Naw Dan, he just got his wings...literally. Thanks bud.
Offline trekker9211
  • Coming home
« Reply #36 on: August 25, 2015, 09:39:16 pm »
A little more chipping and sprayed the exhaust and machine gun port stains. 8)
Offline nkaltso
« Reply #37 on: August 25, 2015, 09:47:14 pm »
nice job on the chipping it looks realistic.  did you use a tooth brush.
also the decals really laid down nice.
Nick
Offline trekker9211
  • Coming home
« Reply #38 on: August 25, 2015, 11:44:38 pm »
Hi Nick, I cut the corner of a sponge, dab it in the paint cap and remove MOST of the paint by blotting it on a paper towel. Kinda like dry brushing with a sponge. Lightly dab it on the place you need it, but it takes a little practice to not overdo it or blob it on because you left too much paint on the sponge. You can cut it into different angles and shapes to get the desired effect and you can simply cut the painted part of the sponge off and reuse it. I also use a fine tip brush too!
As for the decals, I spend a LOT of time applying Micro Sol to get them to settle into the panel lines like that and they are EagleCal decals, which are much better than kit decals.
Thanks for looking! 8)
« Last Edit: August 25, 2015, 11:54:40 pm by trekker9211 »
Offline nkaltso
« Reply #39 on: August 26, 2015, 05:32:47 am »
Chip by adding Im used to chipping by removing.
Thanks for the tip
Nick
Offline trekker9211
  • Coming home
« Reply #40 on: August 26, 2015, 10:53:36 am »
Do you use hairspray or chipping fluid?
« Last Edit: August 27, 2015, 11:36:46 pm by trekker9211 »
Offline trekker9211
  • Coming home
« Reply #41 on: August 27, 2015, 03:35:05 pm »
Chipping is done now so the next step is some dull coat. After that, then some random weathering.
I had to re spray the bottom port wing because in my haste I applied the wash before the clear coat dried completely and it seeped into the clear coat. Now I have to re apply the gloss coat and do the wash again...2 day penalty for impatience on my part! :(
Keep in mind that an overall dull coat will tone down the contrast of the chipping/paint/stain color and will allow me to do some restrained final weathering. The re painted port lower wing looks grey in the pic, I don't know why, but its a couple shades of Lt. intermediate blue . Here's where I'm at now...
« Last Edit: August 27, 2015, 11:46:28 pm by trekker9211 »
Offline nkaltso
« Reply #42 on: August 27, 2015, 09:17:26 pm »
Do you use hairspray or chipping fluid.
Neither I'm hoping to get into it one day.
If you in Detroit come over ill show you some lighting and you show me some chipping.
Nick
Offline trekker9211
  • Coming home
« Reply #43 on: August 30, 2015, 08:51:57 pm »
Almost there and loaded for bear! 8)
I just spotted a split in the port wing I gotta fix. :-\
Offline trekker9211
  • Coming home
Re: 1/32nd scale Corsair finished
« Reply #44 on: September 19, 2015, 12:57:19 pm »
I'm sticking a fork in this one. Learned a lot painting with an airbrush on this build and I'm pretty happy how it turned out. Finished just in time to give to my Son for his Birthday!
Thanks for looking and thanks for the encouragement everyone gave throughout this build. 8)
Part 1 pics
