Author Topic: My Reliant 1/537 AMT kit  (Read 12841 times)
Re: My Reliant 1/537 AMT kit
« Reply #90 on: March 07, 2016, 06:29:41 am »
Looking good as always Shawn.
Been through your thread but seeing as this is the original issue of this kit are you use the upgrade parts for the windows/hull?
« Reply #91 on: March 07, 2016, 08:21:48 am »
Thank you Iain.  I'm just using the original AMT model without the resin saucer upgrades.  So far it has worked out well. The only problem I had so far was fitting the hulls together when the LED's were put in, but I moved the wiring around and it worked.   I will have to strategically place the circuit boards in there, but did a test fit and those look like they are going to fit in there too.
I'm in the middle of moving to a new house so all the model stuff is going to have to stop for months.
I'm pretty sad about that really.  I love working on models, but I have to get ready to move.
« Reply #92 on: March 08, 2016, 08:21:12 am »
Shawn, congrats on the "new house"!
We'll be looking for you when you come back!
Best of luck on the move!
« Reply #93 on: March 08, 2016, 08:24:50 am »
Thanks Steve.  I'll still be here looking at builds in the mean time.
Offline Kuce
« Reply #94 on: March 08, 2016, 02:32:58 pm »
She's looking good.
And the next time you get frustrated with the air brush -- well, rolling DOES help.
« Reply #95 on: March 08, 2016, 02:35:53 pm »
Hahahaha,  Thanks Joe!   Rolling on the floor screaming is more my style.  hahahahaha.
« Reply #96 on: March 08, 2016, 04:12:23 pm »
Good luck with the move, Shawn. And don't let the movers get a hold of your kits. No sense taking chances. ;)
« Reply #97 on: March 08, 2016, 04:32:12 pm »
Thank you Dan.  I'll be the "mover" so hopefully it go ok.   ;)
Offline trekker9211
  • Coming home
« Reply #98 on: March 09, 2016, 12:07:38 pm »
Gonna miss ya while your moving! Protect that build like it's a cracked eggshell and see you when you get back 8)
« Reply #99 on: March 09, 2016, 12:20:28 pm »
Thanks Phil.   I'll be in here bugging you guys anyway about your builds..... somebody's got to do it.  Hahaha
« Reply #100 on: August 09, 2018, 08:40:31 am »
Hi all,
I'm back!   It's been 2 years since I've posted.  I'm done with the house remodel and am now back on board to working on my Reliant.
All the pictures are of 2 years ago.  I just never posted them until now.
I had added a wire harness type thing in the bottom of the hull.  Since then it is all wired up and ready to go.  I got that type of harness so the ship can be separated from the base if need be.
adapter by Shawn McClure, on Flickr
I put a hole in the bottom of the ship to match the size of the wire harness.
Hole in hull by Shawn McClure, on Flickr
(I think) I used the sculpting putty around the harness.
adapter bottom by Shawn McClure, on Flickr
Side view before the putty.
adapter side by Shawn McClure, on Flickr
Inside view.
adapter top by Shawn McClure, on Flickr
Since then I added all the wires.  Tons of them.  I didn't take a picture of that.
I moved on to the planetary sensor.
planetary start by Shawn McClure, on Flickr
planetary block by Shawn McClure, on Flickr
planetary insert by Shawn McClure, on Flickr
planetary on bottom by Shawn McClure, on Flickr
planetary on side by Shawn McClure, on Flickr
It ended up looking light this:
planetary done by Shawn McClure, on Flickr
I've done some other things since then.  I'm also starting the painting of the model. That is kind of hit and miss.
Thank you to MSgtUSAFRet (Steve) for the posting information and support.
Thanks for looking,
« Reply #101 on: August 09, 2018, 07:26:42 pm »
Shawn Back From the Dead!!
Thanks for the Kudos, Bud!
So far its looking good! Keep at it and welcome back!
« Reply #102 on: August 10, 2018, 08:17:13 am »
Thank you Steve, and thank you again for the posting help.
« Reply #103 on: September 18, 2018, 08:20:51 am »
Hi all,
So back to the Reliant. I've been working, but haven't really posted to much so here goes.
Here are some shots of the painting.
beginning paint by Shawn McClure, on Flickr
Top paint by Shawn McClure, on Flickr
top dome by Shawn McClure, on Flickr
Then I painted the nacelles and here they are.
nacelle gold by Shawn McClure, on Flickr
nacelle done by Shawn McClure, on Flickr
I went to light up the shuttle bays using some LED tape.  There was no tolerance for this tape so I had to trench out the top of the saucer to make everything fit.
shuttle bay lights by Shawn McClure, on Flickr
shuttle bay trench by Shawn McClure, on Flickr
shuttle bay lit by Shawn McClure, on Flickr
There are a ton of wires in here.  Three boards control the photons, the strobes and navigation, and the fading in and out of the impulse, warp, and crystal lights.
wiring 1 by Shawn McClure, on Flickr
wiring lit 1 by Shawn McClure, on Flickr
wiring 2 by Shawn McClure, on Flickr
top and bottom by Shawn McClure, on Flickr
wiring lit 2 by Shawn McClure, on Flickr
I'm pretty much ready to put the two halves together.
side shot by Shawn McClure, on Flickr
dark shot by Shawn McClure, on Flickr
Thanks for looking,
« Reply #104 on: October 17, 2018, 07:46:17 am »
Looking good, Shawn!
I see on another site that you are a bit further along than this and it looks fantastic! Are you gonna post some final pics here?
Keep up the good work!
