Author Topic: Arduino: Playmates TNG Cobra phaser mod: Electronics  (Read 893 times)
Offline Jimmypop57
    • Youtube Channel
« on: October 17, 2016, 07:36:28 am »
Hey folks! Taking a short interlude on the dreadnought build, and putting something together for a Halloween costume (if I can get it done in time LOL). I picked up a broken playmates phaser for a few bucks, then went hunting for ways to make it "work" >8^)
I came across an Arduino sketch to do just that! I needed to tweak a few things, but BulldogLowell on the arduino forums was doing stuff I don't know how to do. Basically I just made the sound work via trial and error.
Hopefully I'll be able to get the electronics in, and the phaser a bit more screen accurate for a reveal. Take a look, see what you think. Code is below.
https://www.youtube.com/watch?v=fEZ3hKYNJEo
Code: [Select]
Compliments of BulldogLowell - Ardunio Forums. Mad props for setting this up DOOD!
Press pushButton powerUP whilst in PHASER mode
Press pushButton2 powerDown whilst in PHASER mode
Long Press pushButton Toggle DIAGNOSTIC/PHASER mode
Long Press pushButton2 whilst DIAGNOSTIC switches to OVERLOAD mode
OVERLOAD mode you will see a short stall of the LEDs and it will begin a 10s self destruct sequence.
#define PHASER 0
#define DIAGNOSTIC 1
#define OVERLOAD 2
#define DEAD_STATE 3
const int ledPin[10] = {
  13,11,10,9,8,6,5,4,3,2};
const int scanArray[5] = {
  0b1000000001, 0b0100000010, 0b0010000100, 0b0001001000, 0b0000110000};
const byte pushButton  = 7;
const byte pushButton2 = 12;
int spkr = A0;
byte lastVal;
byte lastVal2;
int index = 0;
byte state = PHASER;// initialises in phaser state
unsigned long timeStamp;
unsigned long timeStamp2;
unsigned long timeStamp3;
void setup()
  Serial.begin(115200);
  for (int i = 0; i < 11; i++)
    pinMode(ledPin[i],OUTPUT);
  pinMode(pushButton,INPUT_PULLUP);
  pinMode(pushButton2,INPUT_PULLUP);
void loop()
  byte val=digitalRead(pushButton);
  byte val2 = digitalRead(pushButton2);
  if (val != lastVal || val2 != lastVal2) delay(50);
  if(val==LOW && lastVal == HIGH && state == PHASER)
    timeStamp = millis();
    index <<= 1;
    index |= 1;
    if (index > 0b1111111111) index = 0b1111111111;
    for (int i = 0; i < 10; i++)
      digitalWrite(ledPin[i], bitRead(index, i));
        tone(spkr, 8000, 50);
  else if (val==HIGH && lastVal == LOW && state == PHASER)
    if (millis() - timeStamp >= 2000UL)
      state = DIAGNOSTIC;
      Serial.println(state);
       tone(spkr, 2000, 50);
  else if (val==HIGH && lastVal == LOW && state == DIAGNOSTIC)
      state = PHASER;
  lastVal = val;
  if (val2 == LOW && lastVal2 == HIGH && state == PHASER)
    timeStamp2 = millis();
    index >>= 1;
    Serial.print("index = ");
    Serial.println(index, BIN);
  else if (val2 == LOW && lastVal2 == HIGH && state == DIAGNOSTIC)
  else if (val2 == LOW && lastVal2 == LOW && state == DIAGNOSTIC)
    if (millis() - timeStamp2 >= 2000UL)
      delay(250);
      state = OVERLOAD;
      timeStamp3 = millis();
      Serial.println("overload");
       tone(spkr, 4000, 50);
  lastVal2 = val2;
  if (state == PHASER)
  else if (state == DIAGNOSTIC)
    diagnogsticScan(false);
  else if (state == OVERLOAD)
    if (millis() - timeStamp3 > 10000UL)
      diagnogsticScan(true);
    else
else if (state == DEAD_STATE)
     if (digitalRead(pushButton) == LOW && digitalRead(pushButton2) == LOW)
       index = 0;//<<<<<<<<<<<<<<<<<<<<<<< added this, that is why i needed to add the curly braces, so both lines will execute after the two button press
       state = PHASER;
void diagnogsticScan(boolean faster)
  static unsigned long scanInterval = 80UL;
  static unsigned long scanStart;
  static byte scanIndex = 0;
  static byte increment = 1;
  if (millis() - scanStart >= scanInterval)
    scanStart += scanInterval;
      digitalWrite(ledPin[i], bitRead(scanArray[scanIndex], i));
    scanIndex += increment;
    if (scanIndex == 0 || scanIndex == 4)
      increment = -increment;
    if (faster)
      scanInterval--;
      if (scanInterval <= 0)
        state = DEAD_STATE;
          digitalWrite(ledPin[i], HIGH);
        delay(250);
         tone(spkr, 550, 50);
          digitalWrite(ledPin[i], LOW);
    Serial.println(scanInterval);
« Last Edit: October 17, 2016, 07:39:00 am by Jimmypop57 »
