Author Topic: Micro File set?  (Read 912 times)
Offline USSBonchune
Micro File set?
« on: January 21, 2017, 05:56:54 pm »
Any one have a lead on a good micro file set? around .5 - .8 mm would be great!
For the record, THIS is why I am asking....DAMN WINDOWS!
« Last Edit: January 21, 2017, 09:06:35 pm by USSBonchune »
"Second star to the right, and straight on till morning"
Offline Jimmypop57
    • Youtube Channel
Re: Micro File set?
« Reply #1 on: January 23, 2017, 08:45:00 am »
Here is the set I picked up from amazon. Maybe this will work for you (they are still a little big for 1:1000 / 1:2500 kits, but you can make do using the tips of the square/round files pretty well).
https://www.amazon.com/SE-744DF-R-Diamond-Piece-140mm/dp/B0011565LG/ref=sr_1_7?ie=UTF8&qid=1485182555&sr=8-7&keywords=jewlers+files
Offline USSBonchune
Re: Micro File set?
« Reply #2 on: January 23, 2017, 10:19:09 am »
That is the exact set I have!
Great minds, eh?  :P
Offline Jimmypop57
    • Youtube Channel
Re: Micro File set?
« Reply #3 on: January 23, 2017, 12:31:31 pm »
 ;D Not sure if they make them smaller, I'll have to check, because that would be awesome for the scales I like to work in for sure! And could be what you are looking for!
Offline Jimmypop57
    • Youtube Channel
Re: Micro File set?
« Reply #4 on: January 23, 2017, 12:33:25 pm »
No sooner than I type this and check, and sure enough... I need to save up a couple $$$ for a set of these. Had no idea they came this small!!!
http://www.micromark.com/12-piece-micro-size-file-set-with-handle,8382.html
Offline USSBonchune
Re: Micro File set?
« Reply #5 on: January 23, 2017, 12:49:54 pm »
oooh, NICE FIND!!
Ordering those suckers right now!
Re: Micro File set?
« Reply #6 on: January 24, 2017, 11:54:09 am »
If you have a Harbor Freight Tools near you, you can always pick up a set of twelve needle files for $3.99 U.S.D..
Link: http://www.harborfreight.com/12-piece-precision-needle-file-set-4614.html
I bought a set a few years back.  Works fine, and is nice and inexpensive.  And if you get their 20%-off coupons in the mail, they end up costing even less!
