Author Topic: Minicraft 1/350 Titanic ... Centennial Edition  (Read 7831 times)
Re: Minicraft 1/350 Titanic ... Centennial Edition
« Reply #60 on: November 11, 2017, 04:39:21 am »
Just tuned back into this one and all I can say is WOW! Your attention to detail is amazing. I love the little trees inside!
You have the patience of a Saint with that PE! Your build maybe the inspiration and kick in the arse I need to pick up work on the QM2 again
Very nice work so far - Be very proud!
Si
« Reply #61 on: November 12, 2017, 02:28:49 pm »
Thanks Madhatter I appreciate the vote of confidence.  :)
I finished getting the promenade walls glued down to the deck and I wanted to get an idea of how things fit.
  Overall I think it's good except for a few exceptions which have nothing to do with me ...  ::)
I fit the top deck on the walls and everything seems to be lining up pretty nicely.
061 Checking fit 1 by Kev C, on Flickr
062 checking fit 2 by Kev C, on Flickr
The challenge will come in the area shown below.
063 checking fit 3 by Kev C, on Flickr
In this area and another area further on the walls extend up past the deck. There is a real sizable gap all the way around on this upper deck where the light will just flood through, not to mention that it is a very visible gap in the deck.
065 checking fit 5 by Kev C, on Flickr
I put the 'roof/deck' on the section and took the next photo. You can see the gaps I have to contend with at some point.
064 checking fit 4 by Kev C, on Flickr
Obviously the designers of this kit never intended for this kit to be lit, let alone have people want to make it as accurate as possible, but wow! ....  ???
I have some very thin LED strips on order from HDA MOdelworx to use as lighting along the promenade decks and other small areas. Once that gets here I should be able to start getting things organized for lighting the promenade deck and move on.
Onwards and upwards!
Thanks for looking.  :)
« Last Edit: November 12, 2017, 02:32:03 pm by karve »
« Reply #62 on: November 13, 2017, 12:10:48 pm »
Kevin, this is looking impressive - per your usual work!
For the gaps, I don't know if you have used or heard of Perfect Plastic Putty (PPP) but I can see it being, uh, "perfect" for filling those gaps! It has pretty good light blocking properties, depending on thickness, but it would probably be a good idea to lightblock it with paint anyway.
« Reply #63 on: November 13, 2017, 01:40:21 pm »
Thanks Steve .. I have PPP and have used it. I've also ordered a jar of Liquitex Professional Light Modeling Paste. I've heard some good things on the forum about it so I thought I'd order some and see how it goes. I may try using one of those or I have a couple other ideas bouncing around my pea brain.  ;D
« Last Edit: November 13, 2017, 02:38:45 pm by karve »
« Reply #64 on: November 14, 2017, 08:04:06 am »
You said "pea brain" and all I could think about was this!
 ;D ;D
Keep going, Kevin! I am enjoying your build!
Offline Rusty_S85
« Reply #65 on: December 13, 2017, 09:43:50 pm »
Nice.  I see you are using fiber optics as well as LED strip lights.  Interesting combination.  I have a 1:350 scale Titanic I started on then decided to light up but progressed too far.  Hope to get some ideas for mine.  I'm thinking of running warm white LED strip lights then dropping wattage down enough to get the brightness the right level.
« Reply #66 on: January 11, 2018, 08:13:56 am »
Hey, Kevin!
Haven't seen you post in a while. What's going on here! Anything new?
« Reply #67 on: January 11, 2018, 10:35:29 am »
Oh, wow, this LED lit model will look great in the dark I think! :) The more lighting the better.
« Reply #68 on: February 10, 2018, 07:41:21 am »
Sorry I've been absent for a while guys. Just taking a break again. I got busy over the holidays and work has been hell ...  VERY stressful the last several months. I just haven't had any 'energy' (mental or physical) left over to work on my model. Hopefully I'll be back at it soon.
« Last Edit: February 11, 2018, 05:14:04 am by karve »
« Reply #69 on: January 04, 2019, 09:55:03 am »
Hi all
Sorry it's been so long since I've posted in this thread but I've been away from the hobby for over a year. However, I'm ready to get back at it and will be working away on my Titanic again soon. First I'm going to get my feet wet again with another project, then I'll dive back in here.
« Reply #70 on: January 05, 2019, 07:10:32 am »
Karve,
Welcome back! Sometimes RL gets too much to model. Understood. Breaks are necessary.
But its good to see you back at it. Post your project and I will be following along!
Life's great if you don't weaken! :)
