Author Topic: Why no molded Aztec Plating Kits  (Read 430 times)
« on: July 29, 2017, 08:42:24 pm »
I know a lot of people hate the 537 1701 Refit kit with the 'brick hull' pattern.  Why haven't they made a kit that instead of the 'brick' pattern, rather have the Aztec pattern engraved in the hull?
Re: Why no molded Aztec Plating Kits
« Reply #1 on: July 29, 2017, 09:27:37 pm »
The brick pattern was not a good idea, and very inaccurate.
Unfortunately  it ruined  the smoothie 1/537 molds so it could not be fixed.
Ideally the Aztec pattern should not have relief, so newer kits like the 1/1000 and  1/350 are smooth and modellers add the pattern with paint or decals
« Reply #2 on: July 30, 2017, 12:38:48 pm »
I think if they made it with light etch lines and not nearly as deep and heavy as the brick pattern it would look fine.
« Reply #3 on: July 30, 2017, 01:06:56 pm »
True, and ERTL did that for the 1701 D model when TNG came out.
« Reply #4 on: July 30, 2017, 01:45:55 pm »
Yes sir you are right!  I never noticed that before.  After you posted that I grabbed my 1701D saucer and low and behold yepper, it has the Aztec pattern!  I never noticed that before, it's subtle but there.  It will take a lot of work with Liquid mask, but when I get around to finishing my D I'm going to use the pattern on the kit instead of decaling it with the wallpaper decals.
Now if they did a 1701 Refit like that...  :)
