Author Topic: Spindrift from Land of the Giants by Polar Lights  (Read 9181 times)
Re: Spindrift from Land of the Giants by Polar Lights
« Reply #75 on: April 09, 2018, 09:48:03 pm »
What Steve said! That's really too bad about the window crap. But don't let it detract from the outstanding and inspirational work you have done on this less than perfect kit. I still say Bravo!!
« Reply #76 on: April 11, 2018, 12:04:53 pm »
Decided to unmask the bow window ports in case any of the tape had come unsealed along the edges. Was planning a quick re-masking with fresh tape before priming when I noticed one of my worst fears.... Both windows had a tiny bit of "crap" on the inside surface??? It was quite clearly visible; and the model was now most truly and assuredly sealed up.
No way to remove it.
That's a shame Steve.....   sorry to hear it. No way to push the windows through and replace them?
Offline trekriffic
  • Lord Dark Spot
    • My Albums
« Reply #77 on: April 12, 2018, 05:33:24 pm »
Thanks for the encouraging words guys. Much appreciated.
Soooooo.... anyway, here's a photo of the funk on the windows:
Junk by trekriffic, on Flickr
I was not going to stand for that so...
I removed the clear window plastic using a scribing tool and Tamiya mini-photo-etch saws:
Window Removal by trekriffic, on Flickr
With the windows out I decided to take some photos of the cabin with the lights on:
Pilot's cabin roof by trekriffic, on Flickr
Pilot's Cabin Lit without Windows by trekriffic, on Flickr
Making replacement windows using Evergreen .015 clear styrene sheet. Have to be careful not to scratch them during installation:
Making New Windows by trekriffic, on Flickr
Stay tuned!
Him: "Not Chinese!"
« Reply #78 on: April 12, 2018, 06:52:55 pm »
Nerves of steel ...
You'll get there. Looking fantastic so far!
« Reply #79 on: April 13, 2018, 05:44:23 am »
I was certain you would NOT have dirty windows on this one Steve.....   We're very proud of you young man!
"So say we all"
Offline trekriffic
  • Lord Dark Spot
    • My Albums
« Reply #80 on: April 13, 2018, 10:51:15 am »
Thanks for the vote of  confidence guys. I used a technique from my Apollo LEM build to make gaskets inside the window frames to prevent the window panels from falling thru when I glue them in. You take black adhesive-backed vinyl paper and cut thin strips to lay along the inside back edge of the frame. You can layer the strips to make the gasket as thick as you need. I'll post some pics later but the panels seem to fit really well, at least at the test fit stage.
Him: "Not Chinese!"
Offline trekriffic
  • Lord Dark Spot
    • My Albums
« Reply #81 on: April 14, 2018, 12:16:07 pm »
Update for today...
I used this technique in my Apollo 11 Eagle build to separate the two glass (?) panels in the upper docking window port of the LEM. Only that time I used red adhesive backed vinyl strips. I cut thin strips of black sticky backed vinyl thin enough to fit along the back edge of the bow window rims, leaving enough room for the clear styrene window plastic to fit inside the rim up against the vinyl gasket:
Adhesive Backed Vinyl Paper Makes Gaskets by trekriffic, on Flickr
Starboard window install...
The inside of the frame was coated with Elmer's clear craft glue. Then I removed the tape on the backside of the clear plastic pane and cleaned it with alcohol and a clean cotton shirt. I left the masking tape in place on the outside of the window to protect during installation:
Starboard Window Installed by trekriffic, on Flickr
Satisfied it was clean I gently placed the window pane into the frame; then over a few minutes I adjusted its position inside the rim. I also gently held down the edges as the glue dried:
Starboard Window In Place by trekriffic, on Flickr
Both bow windows glued in place:
Both Bow Windows Glued In Place by trekriffic, on Flickr
Masks removed...
I'll lay in some more of the clear craft glue. That stuff is great for windows being water based and clear:
Mask Removal by trekriffic, on Flickr
Need to remask the bow windows after the putty dries around the frames then she'll get a shot of black to hide any remaining light leaks., then grey primer, followed by white primer, followed by yellow, followed by orange. Think I'll airbrush all of these layers to avoid many thick layers from a rattle can:
Spindrift So Far by trekriffic, on Flickr
Dorsal fin detail...
I was happy with how this turned out; extending the sidewalls of the channel the fin slides into so it continues on in a smooth line where the hull breaks:
Dorsal Fin Detail by trekriffic, on Flickr
One more gratuitous profile shot...
Oh God... I still, need to finish the stand...
Him: "Not Chinese!"
« Reply #82 on: April 18, 2018, 04:41:58 am »
Nice save on those front windows....  I'll remember that trick!    :b
« Reply #83 on: April 18, 2018, 07:21:51 am »
Nice technique with the gaskets, Steve!
After you cleaned them, I was surprised you didn't use Future on the windows to make them even more clear; or did I miss something?!
Excellent build!
Keep going! And don't forget the stand! :)
Offline trekriffic
  • Lord Dark Spot
    • My Albums
« Reply #84 on: June 13, 2018, 12:04:45 pm »
Well almost two months since my last post and not much progress to report.
Most of my time has been devoted to coordinating improvements to my house.
So dealing with a lot of upheaval with new flooring, new countertops in the kitchen and baths,
and new interior wall paint.
Thankfully we're in the home stretch so hope to see a return to normalcy in the near future.
In the meantime here are the last set of pics showing the Spindrift in various stages of priming,
puttying and sanding, more priming, and more sanding, she's got a coat of white primer on her now.
Anyway, here goes...
I masked the windows with Tamiya masking tape and brushed on some Future to seal around
the edges to keep paint from bleeding under the tape:
Bow Windows by trekriffic, on Flickr
I brushed on some liquid Tamiya grey primer then sanded smooth again:
More Primer by trekriffic, on Flickr
The grills and window frames got another brushing with Tamiya primer after puttying:
Brush Primed Windows by trekriffic, on Flickr
She got a shot of flat black Testors enamel for light blocking:
Black Spindrift by trekriffic, on Flickr
Testors silver points out any remaining flaws that need to be addressed:
Silver Spindrift by trekriffic, on Flickr
Here she is just after spraying with Testors matte white enamel.
After this she gets a coat of yellow followed by Italian red:
White Spindrift by trekriffic, on Flickr
Closeup of Bow by trekriffic, on Flickr
More to come... soon I hope...
Him: "Not Chinese!"
« Reply #85 on: June 14, 2018, 07:08:07 am »
Hey, Steve! Glad to see you're back at the bench.
I was wondering if you were gonna finish this or had and hadn't updated us yet.
Thanks for the update and, as usual, I love your work!
Offline trekriffic
  • Lord Dark Spot
    • My Albums
« Reply #86 on: October 21, 2018, 06:02:16 pm »
Well the airbrush booth arrived a few days early so I assembled it this morning:
New Airbrush Booth by trekriffic, on Flickr
This is a portable booth and folds up into a case which I can't foresee me doing anytime soon so after unfolding it I snapped the LED bars into place and lined the interior surfaces with heavy bond watercolor paper which I taped to the walls and ceiling. Should make cleanup a lot easier:
Airbrush Booth Front by trekriffic, on Flickr
I gave the Spindrift a quick going over with canned air and, now satisfied it was free of dust, placed it onto the painting stage. I also got a set of these yellow triangular blocks to lift the model up:
The Spindrift Ready for Yellow Coat by trekriffic, on Flickr
Here she is after spraying the upper hull with Testors Flat Yellow. I'll give it a day to dry before spraying the underside:
Yellow Spindrift by trekriffic, on Flickr
After the yellow coats have dried and been lightly sanded she'll get her final coats of Italian Red.
Thanks for reading and sticking with me for all these months everyone!
Him: "Not Chinese!"
« Reply #87 on: October 23, 2018, 01:21:30 pm »
Very nice Steve.....   Now your model matches the little triangular thingies.....  aren't you glad they were not made clear?   :b
Offline trekriffic
  • Lord Dark Spot
    • My Albums
« Reply #88 on: November 14, 2018, 11:46:32 am »
Sorry for the delay in posting. Been preoccupied with less Giant concerns lately...
I flipped her over:
Preparing to Spray Yellow by trekriffic, on Flickr
Then I sprayed the underside:
Spindrift Underside in Yellow by trekriffic, on Flickr
Here she is in profile:
Spindrift Canary - Middle Color by trekriffic, on Flickr
Spindrift Canary by trekriffic, on Flickr
When my Italian Red "enamel" turned out to be acrylic I went to plan B and used Testors Grapefruit, at least for the first "final coat". This has a slight brick red aspect to it. A nice orangy-red I think:
Spindrift Final Coats by trekriffic, on Flickr
After drying she got her first Glosscotes:
Spindrift Unmasking by trekriffic, on Flickr
Ready for some unmasking? I sure am!
Yipee! I had tested all the lights and they all worked before I masked the model but there is always that moment of trepidation when you unmask months later...
Dome unmasked and lit:
Spindrift Dome Light Test by trekriffic, on Flickr
Front Grills Unmasked. I may leave the windows masked until the decals are done and the final finish coats are applied:
Engine Intake Grills Unmasked and Cleaned up. Glosscoted:
Spindrift Unmasked by trekriffic, on Flickr
Rear engine grills needed minimal cleanup and just some light touchup with Testors Flat Steel and Flat Grapefruit enamels:
This color has really grown on me:
She has a shark-like aspect doesn't she?
Him: "Not Chinese!"
« Reply #89 on: November 15, 2018, 09:07:26 am »
Wow, Steve, this looks beautiful! Very well done!
Still looking forward to see the final product!
