Author Topic: Testing various flat clears over Future (some final thoughts ...)  (Read 5415 times)
Liquid Electron
Re: Testing various flat clears over Future.
« Reply #30 on: November 09, 2017, 08:24:20 pm »
If I didn't have so much Liquitex matte sitting around, I'd go for some Krylon matte.  Heck, I probably will anyway.  Will continue watching :)
« Reply #31 on: November 09, 2017, 10:53:30 pm »
Yeah, so far it has been the best for me. Your milage may differ. Just be aware that too much can "go milky on you".
« Reply #32 on: November 12, 2017, 07:38:37 pm »
TEST NUMBER 6
Alclad II Klear Kote Flat
I'll come clean and say it, I avoid lacquers when I can, but I thought I would give Alclad II a go and see what would happen.
I do plan on using Alclad in the future for a couple figure kits (but probably not the flat clear).
From what I've read, Alclad needs to have a pretty smooth, uniform, and sometimes glossy, undercoat to spray well and Future can do that. So, for this test,
I sprayed the upper half of the test wedge with Future as uniformly as I could and then sprayed the lower half unevenly to see if it would have an effect. Some spots
I gave a lot of Future, and others only a couple lighter coats. If there was going to be some kind of incompatibility, I suspected this would be it ...
You have to shake the clear a lot to get it evenly mixed. When I tried to take the cap off ... CRACK ... it broke. Not sure what happened. There's a plastic
insert to keep the clear from getting to the threads, but I suspect some managed to get there during shipping. I don't know how common this problem is.
Fortunately, I had a another cap on hand that fit.
Alclad can be sprayed straight from the bottle and is cleaned up either with their airbrush thinner or lacquer thinner. Recommended pressure is 18-20 PSI
and very close distances, treating the airbrush more like a pencil than a sprayer.
This is what I got after three light coats.
As you can see, the upper part is pretty flat and uniform, while the lower is not. How well you spray the Future definitely seems to have an effect as I expected ...
So the lesson here, for me at least, is to be very mindful of your gloss coat. I suspect most of you who have sprayed Alclad before probably know this.
There is a rough spot to the right of one of the center hull plates you can see in the image. The Future here was particularly thin so it might be some kind
of interaction. Everywhere else, where the Future was thicker, seemed to be fine.
As for a comparison of the other flat clears. This is about as flat and smooth as the Krylon Matte. So if you're comfortable with Alclad, I think it should do the job ...
I personally don't plan on using it, but will if the need arises.
SUCCESS BUT BE MINDFUL OF YOUR GLOSS COAT.
Current Rank
1.) Krylon Matte Finish
2.) Model Master Acryl Flat
3.) Krylon UV-Resistant Clear (Matte)
4.) Alclad II Klear Kote (Flat)
5. - tie.) Testors Dullcote Spray Lacquer
5. - tie.) Valspar Project Perfect Clear Matte
I'll be off for a few days to help out my folks and to reorganize my workspace.
The last two tests will be witch's brews of Future+Tamiya Flat Base along with Liquitex Matte Varnish+Airbrush Medium.
« Last Edit: November 12, 2017, 07:50:59 pm by Spencer »
« Reply #33 on: November 15, 2017, 09:26:40 am »
TEST NUMBER 7
Future + Tamiya Flat Base (X-21)
I had a little time this morning to quickly try this witch's brew ...
I've seen this mixture mentioned on other threads and forums and it got my interest.
It's pretty cheap to make. I got the flat base for $2.39 at Scalehobbyist and a bottle of Future will last you a good while.
From Swanny's Models, the recommended mixes are:
       1 part flat base to 3 parts Future   = very flat
       1 part flat base to 10 parts Future = flat
       1 part flat base to 15 parts Future = satin
Any more base and you run the risk of the clear coat developing flakes or turning milky. So, for the sake of maximizing success, I decided
to mix:
       1 part flat base to 5 parts Future
knowing that it might not give me as "dead flat" of a finish as some of the other tests.
I used a graduated pipette to get the ratios right.
Spraying at 15 PSI a few inches from the surface, I put down 5 light coats as evenly as I could with a
couple minutes between each coat. There were a few shiny spots, but they leveled out and turned flat.
Here is the result...
I think I have a new favorite contender! This stuff is just as smooth as the Krylon Matte and UV Clear, is maybe
a tiny bit less flat than Kryon Matte and is more uniform than the MM Acryl Flat. I can easily see why a 1:3 mix
might be "too flat". Cleanup was easy, just some denatured alcohol and/or ammonia diluted to 5%. I used ammonia
last because Windex is known to gum up the Tamiya. Simple Green should also work.
I don't think it needs to be said but I'll say it, no signs of interaction with the Future gloss coat underneath.
With a bit of tweaking, this might just be my go-to for airbrushing. The fact that you can experiment with, and
then control the amount of gloss you get is a big plus IMO.
SUCCESS BUT SOME TWEAKING REQUIRED.
Current Rank
2.) Future + Tamiya Flat Base
3.) Model Master Acryl Flat
4.) Krylon UV-Resistant Clear (Matte)
5.) Alclad II Klear Kote (Flat)
6. - tie.) Testors Dullcote Spray Lacquer
6. - tie.) Valspar Project Perfect Clear Matte
I need to spray some Future on the inside of the saucer for the last test, so it will be the weekend before I get to that.
« Last Edit: November 15, 2017, 09:30:14 am by Spencer »
« Reply #34 on: November 20, 2017, 12:46:38 pm »
TEST NUMBER 8
FINAL TEST:
Liquitex Matte Varnish + Liquitex Airbrush Medium
This is the last thing I'll be testing.
Liquid Electron suggested trying this stuff, so I first
bought a bottle of Airbrush Medium and Matte MEDIUM, thinking
that would suffice. But after a bit of reading online, there
were claims that Matte VARNISH gives slightly better results,
so I got a bottle of that to use instead.
I don't claim to be a typical artist, so I won't pretend to
understand Liquitex's system. Mediums, varnishes, flow aids ...
maybe I'll try to wrap my head around it some day.
Anyway, the suggestion was a 70/30 mix of varnish and medium and
to spray from 30-35 PSI. Since my typical airbrush and compresser combo
tap out at >30 PSI, I went with 28 PSI and used a bigger needle.
It already looks like 2% milk ...
This test was done on the underside of the saucer where I sprayed and
sanded some gray primer, then Future without completely glossing over
all the primer. After an even coat, then another light pass, here is the result:
Can you tell where the flat ends and primer begins, because it's pretty tough for me ...
I am quite impressed. It looks very flat and uniform, about on par with the
Krylon Matte and Future + Tamiya. It's a bit rougher texture, comparable to the MM Acryl Flat and ...
no interaction with the Future.
The only catch is to clean your airbrush AS SOON AS you are done spraying. Let in dry in the brush
and you'll have problems. I didn't have any issues using Windex and a little rubbing alcohol.
This is good stuff. A shoutout to Liquid Electron! I'll use it, at least what I have, on smaller
projects, so that I limit the amount of time it stays in the brush.
SUCCESS BUT WASTE NO TIME CLEANINIG YOUR BRUSH.
Current Rank
2. - tie.) Future + Tamiya Flat Base
2. - tie.) Liquitex Matte Varnish + Airbrush Medium
I could be testing other sorts of clears till the cows come home, but I think I've
amassed a hefty enough list of things to use for now.
I'll be posting my final thoughts and conclusions on this soon.
« Last Edit: November 24, 2017, 12:43:11 am by Spencer »
Liquid Electron
Re: Testing various flat clears over Future (FINISHED TESTING)
« Reply #35 on: November 20, 2017, 01:15:08 pm »
Good stuff!  I'll keep sticking to my Liquitex. :)
Re: Testing various flat clears over Future (some final thoughts)
« Reply #36 on: November 21, 2017, 07:36:27 am »
CONCLUSIONS AND FINAL THOUGHTS
Now that I've had some time to think about the results, here are my thoughts
on the whole experience. I'll try not to be TOO long winded.
One may wonder why I did all this. Afer asking around and looking at
various forums and threads about what flat clears to use, it seemed like there
were as many recommendations and opinions as there were responses. It's a matter
of personal preference and experience. So, I decided to test out what would work
for me. Your results and experiences likely differ, perhaps even significantly,
from my own. I've tried to be as objective in testing as I can, but my impressions
are obviously more subjective.
First, I started these tests to see what would and would not work with Future.
Turns out nearly everything worked. Alclad might interact if the Future is
sprayed on too thin, but that wouldn't be surprising since Alclad is advertised
as a lacquer. Straight 91% rubbing alcohol will cut Future. I know because I had a
spill and it did the job. Other than that, Future seems to be fairly tough.
Second, I wanted to build a list of flat clears that were readily available or
easy enough to get online for me. I tried to weigh each based on how easy they mixed
if needed, how well they sprayed, how easy it was to get a unifrom coat, how smooth
the coat became, both in look and feel and how flat the final finish was.
Here is my list, broken into spray cans and airbrush mixes, with a few notes:
Spray Cans
1.) Krylon Matte Finish  (can turn milky if too much is used)
2.) Krylon UV-Resistant Clear Matte  (use in light coats)
3.) Testor's Dullcote spray lacquer  (very light coats, last option)
Airbrush
1.) Future+Tamiya Flat Base (Larger projects, better control over the final luster)
2.) Liquitex Matte Varnish + Airbrush Medium (Smaller projects, clean brush immediately afterwards)
3.) OR Model Master Acryl Flat (no pre-thinning required, use a larger needle)
I understand there are many, many more choices than this. And, if I come across something else
in the future, I'll test it out and make the results known, if not known already. I could
test for weeks and break the bank, but I think 8 different tests are good enough for now.
Finally, I want to thank all the users who chimed in on sugesstions and opinions. And
remember, just because something worked well, or poorly, for me does not mean it will
as well for you, so take it for what it is.
If anyone wants to discuss further, by all means ...
« Last Edit: November 21, 2017, 07:40:53 am by Spencer »
Offline MarkW
  • Plastic Surgeon
    • MW ModelWerks
Re: Testing various flat clears over Future (some final thoughts ...)
« Reply #37 on: December 05, 2017, 12:51:17 pm »
Coming very late to this party, but wow, what a detailed and scientific approach.
One Caveat:  Be sure the Future is really dried and cured before spraying any Krylon.  If you go too heavy on paint that is still drying, cracking can occur.  Followed closely by wailing and gnashing of teeth.
MarkW
--Brock Sampson
NEW WEB ADDRESS
« Reply #38 on: December 05, 2017, 01:07:19 pm »
Indeed, make sure the Future is completely cured. I tend to give it a week.
I began all this knowing very little about spraying Future and what would or would not work with it, so I figured why not take the time to build up a list
of what works for me. I suppose it was my scientific profession that influenced the methodology.
Offline nkaltso
« Reply #39 on: December 13, 2017, 08:33:46 pm »
thanks for your hard work with your experiment.
Im very careful with paints,  Ive had compatibility issues in the past.  Mainly with anything Rustolieum
I can tell you that now I use Duplicolor adhesion promoter with primer, velhajo paints, and the Krylon clear coats with no issues.
I hope this helps
Thanks
nick
« Reply #40 on: January 16, 2018, 12:52:30 am »
Spencer,
This is some really good work.  Thank you for documenting it all so thoroughly here.
« Reply #41 on: September 27, 2018, 07:16:17 pm »
Spencer - this has proven to be an invaluable resource. Thank you so much for putting this together - it is quite comprehensive and thorough.
From my own experiences, I would suggest to anyone reading this thread that the best approach is to use Krylon Matte as your intermediate sealer and then use your choice of flat for your final covering. Krylon Matte is more satin than flat and will not leave a dusty or rough finish which can ruin a model (trust me, I know).
Also, humidity and PSI (if spraying by airbrush) play a big role here, so be mindful. I find that I need to spray flats (and my current favourite is the Alclad product) at around 10-15 PSI. And not when it is humid; you do not want the clear drying before it hits the model, or you get the rough or dusty finish.
« Last Edit: September 27, 2018, 07:21:21 pm by RossW »
« Reply #42 on: September 27, 2018, 07:52:59 pm »
What airbrush are you using for spraying Alclad?
These are all very good points BTW.
I find the Krylon matte is good because it's somewhat cheap and easily available for me (e.g. Walmart). I found its sheen to be on par with the UV-Clear, but I think using it as a barrier between your color coats and final flat is an excellent idea!
I will also say that I have since warmed up to Alclad, now that I have a proper respirator and spray setup.  ;D I have an Iron Man and War Machine kit that have been whispering to me ...
Also, since my last post here I used the UV-Clear on my 1:1000 D7 and it was a very "no-muss, no-fuss". A couple light coats and I was done. Keep in mind though that I was shooting for a little bit of sheen on that kit (like I believe those classic ships should have).
« Reply #43 on: September 28, 2018, 06:32:15 am »
Hey Spencer, thanks for all this work -- it's very helpful.  I've used just about all these products over the years but never have seen them perform in a side-by-side comparison.  For larger models I like both of the spray Krylon products for coverage and ease of use.  For smaller projects, I go with Vallejo Matte Varnish, thinned around 20% for airbrushing, which goes on silky smooth.  Thanks again!
« Reply #44 on: September 28, 2018, 07:18:41 am »
No problem!
I've been thinking about trying Vallejo varnishes. I've toyed around with Model Air and Model Color when I've had the time the past couple months. The varnishes are one
of the few Vallejo products my "local" Hobby Lobby carries when they're actually in stock ...
Do you just use +20% of their airbrush thinner for that? PSI range? Cleanup? ... Sorry, but you know I gotta ask now.  ;D
« Last Edit: September 28, 2018, 07:20:58 am by Spencer »
