Author Topic: Star Destroyer engine ignition effect, need help...!  (Read 1000 times)
Offline Often wrong Soong
« on: May 20, 2018, 03:07:20 pm »
Hi guys, bit of a long post here so thanks if you make it to the end!
I've recently taken the plunge into micro controllers and have been trying to wrap my head around it all for a couple of weeks now.  Unfortunately, I'm really struggling to make much sense of anything passed the real basic stuff and seem to get swamped with it all quite quickly.  I guess my mind just doesn't work very well that way.  I have been tinkering with some of the codes that have been very generously shared by some of you guys here (Gadgetron_3000, RossW, Spencer etc, you guys are awesome for that, thank you!!) and have been able to get most basic stuff I may need but there's one effect that I just can't get to grips with.  I'm positive that it's such an easy thing to achieve too, which really frustrates me, but I'm begging for back-up from better minds than mine!!
Basically, I'm after an engine ignition cycle (for a Star Destroyer or Viper etc) which will fade 3 LED's up and flicker as if at full power, with each starting it's fade/flicker cycle at slightly staggered (but overlapping) timings, before shutting down and fading off, again at staggered overlapping times, after a single button push.  E.g: After a button push LED1 begins to slowly fade up and flicker, LED2 would wait for, say 1sec before beginning it's own fade up and flicker, then LED3 would begin it's cycle slightly after LED2.  Then each LED would shutdown at slightly different timings and fade out.
I've managed to adjust a code shared by Spencer in another thread (http://scifimodelaction.com/sfmaforum/index.php?topic=7135.0) to get the fade up and flicker effect I'm looking for, and have added 2 more LED's to the code, which is great but it only clones the effect over the 3 channels.  I can't for the life of me figure out how to introduce the timing separations so each LED channel starts it's fade/flicker cycle at slightly different times, or even how to include the button push to trigger the whole sequence!
Any help or advice would be very much appreciated, my brain feels like it's leaking out of my ears
Here's the code I've been butchering:
#define LED_FLICKER1_PIN 9        //sets the variable "LED_FLICKER_PIN" to pin number(s), needs to be a pwm pin;
#define LED_FLICKER2_PIN 10
#define LED_FLICKER3_PIN 11
static int lowest_low = 190;
static int highest_low = 200;
static int lowest_high = 200;
static int highest_high = 255;
static int shortest_on = 5;
static int longest_on = 10;
static int shortest_off = 5;
static int longest_off = 8;
static int fade_time = 4000; // time to fade up, in milliseconds
// time keeping
unsigned long currentMillis;
unsigned long flickerMillis;
// various bookeeping things
boolean led_flicker_state = 0;
int on_time;
int off_time;
int high_brightness;
int low_brightness;
int fade_brightness;
void setup() {
  pinMode(LED_FLICKER1_PIN, OUTPUT);   // set pin as output
  pinMode(LED_FLICKER2_PIN, OUTPUT);
  pinMode(LED_FLICKER3_PIN, OUTPUT);
  // intially randomize the params
  low_brightness = random(lowest_low, highest_low);
  high_brightness = random(lowest_high, highest_high);
  on_time = random(shortest_on, longest_on);
  off_time = random(shortest_off, longest_off);
void loop() {
  // get the time
  currentMillis = millis();
  if (currentMillis <= fade_time) {
    fade_brightness = int(255.0 * float(currentMillis) / float(fade_time));
    analogWrite(LED_FLICKER1_PIN, fade_brightness);
    analogWrite(LED_FLICKER2_PIN, fade_brightness);
    analogWrite(LED_FLICKER3_PIN, fade_brightness);
  // then the flicker
  else {
    // When it's time to change states, write it out, reset the time and randomize again
    //    for the next time to change states
    if (currentMillis - flickerMillis > (led_flicker_state ? on_time : off_time)) {
      analogWrite(LED_FLICKER1_PIN, (led_flicker_state ? high_brightness : low_brightness));
      analogWrite(LED_FLICKER2_PIN, (led_flicker_state ? high_brightness : low_brightness));
      analogWrite(LED_FLICKER3_PIN, (led_flicker_state ? high_brightness : low_brightness));
      flickerMillis = currentMillis;
      led_flicker_state = !led_flicker_state;
Congrats on reaching the end of the post....bonus points for stamina!!
Wayne
Offline texastony1946
Re: Star Destroyer engine ignition effect, need help...!
« Reply #1 on: May 20, 2018, 03:45:14 pm »
I have tried to make this flicker fade work for some time. I accomplished some of this with my Gundam code. Still trying to make it repeat, and not block. Good luck with this one, I am certainly interested in seeing it work.
« Reply #2 on: May 23, 2018, 10:41:36 am »
Instead of just duplicating the analogWrite statements and putting them into the same if and else blocks, I think you need to duplicate the if and else blocks of code for each LED.
That way the flicker times for each LED should randomize separately and not "sync up". It'll also allow you to set different fade_up times for each LED before the flicker happens.
Try and see if you can get that to work first.
Good luck ...
« Reply #3 on: May 25, 2018, 04:42:41 pm »
Good luck ...
Thanks for the advice Spencer, it's very much appreciated.  I've been forcing myself to keep trying until some of it starts to stick!  Some of it must be sinking in too because I've managed to get the 3 LED's to fade in at staggered times and flicker with independent values by taking your advice and also adding a "wait time" parameter.  To be honest, I'm still not really fully sure why the code actually works, and I know for a fact that there has to be a much more elegant and simple way to achieve the same effect, but here's my butchered Frankenstein's code:
        //set variable "LED_FLICKER_PIN#" to pin# (pwm pins only)
#define LED_FLICKER_PIN1 9                            //pin 9
#define LED_FLICKER_PIN2 10                           //pin 10
#define LED_FLICKER_PIN3 11                           //pin 11
static int lowest_low=150;                            //brightness variables
static int highest_low=180;
static int lowest_high=200;
static int highest_high=255;
static int shortest_on=5;                             //pulse duration variables
static int longest_on=15;
static int shortest_off=5;
static int longest_off=15;
static int fade_time=700;                             //LED1 fade up time
static int fade_time2=750;                            //LED2 fade up time
static int fade_time3=1000;                           //LED3 fade up time
static int step_time = int(float(fade_time/255));
static int wait_time1=750;                            //match value to "fade_time2" for smooth transition
static int wait_time2=1000;                           //match value to "fade_time3" for smooth transition
// time keeping
int on_time;
int off_time;
int low_brightness;
void setup() {
  pinMode(LED_FLICKER_PIN1, OUTPUT);   // set pin as output
  pinMode(LED_FLICKER_PIN2, OUTPUT);
  pinMode(LED_FLICKER_PIN3, OUTPUT);
void loop() {
//-----------------------------------LED1--------------------------------------------------
  // get the time
  // then fade
  if (currentMillis <=fade_time){
    analogWrite(LED_FLICKER_PIN1,fade_brightness);
  // then flicker
  else{
    if (currentMillis - flickerMillis > (led_flicker_state ? on_time : off_time)){
      analogWrite(LED_FLICKER_PIN1, (led_flicker_state ? high_brightness:low_brightness));
//------------------------------------LED2-----------------------------------------------------------
  // get the time
  //wait before starting fade
  if (currentMillis <= wait_time1){
  else{
  // get the time
  // then fade
  if (currentMillis <= wait_time1+fade_time2){
    fade_brightness = int(255.0 * float(currentMillis) / float(fade_time2));
    analogWrite(LED_FLICKER_PIN2,fade_brightness);
  // then flicker
  else{
      analogWrite(LED_FLICKER_PIN2, (led_flicker_state ? high_brightness:low_brightness));
//------------------------------------LED3-------------------------------------------------------------
  // get the time
  if (currentMillis <= wait_time2){
  else{
  // get the time
  // then fade
  if (currentMillis <= wait_time2+fade_time3){
    fade_brightness = int(255.0 * float(currentMillis) / float(fade_time3));
    analogWrite(LED_FLICKER_PIN3,fade_brightness);
  // then flicker
  else{
      analogWrite(LED_FLICKER_PIN3, (led_flicker_state ? high_brightness:low_brightness));
}//end main loop
