Author Topic: Need help: Fiber Optics and light blocking  (Read 339 times)
Offline Valiant
« on: May 29, 2018, 10:26:49 am »
So Im working in a 1400 Enterprise D (a wip post may soon follow), and with my nacelles I'm using 1mm fiber optics to light aft strobes. My problem is, they are picking uo a lot of blue light absorption. I don't normally work with fiber optics, so my question is, is there anything i can do to prevent them from picking up the ambient light without adding a lot of mass (like shrink wrapping) so it doesnt cause an unsightly shadow.
Re: Need help: Fiber Optics and light blocking
« Reply #1 on: May 29, 2018, 10:38:44 am »
Hi
Could swapping the FO out for suitably sized SMD's be an option for you?
I am sure someone with experience in this kit will be along with an answer for.
Offline Valiant
« Reply #2 on: May 29, 2018, 11:15:38 am »
I've considered that, but I was looking for a specific diameter and didnt want the light flush - with a fiber optic i could flare it amd give a nice bulb effect at the right diameter.
I guess I could just mount it flush and us the fiber just for the top but that also would require 4 bulbs insteas of the planned 2 and more resisters etc. M I just don't like that idea as much. Ideally if i can light block the fibers someway whather paint or a better product thats how I would wamt to go.
« Reply #3 on: May 29, 2018, 11:28:00 am »
I use black tulip paint and coat the fiber with it from where it goes through
the nacelle or hull all the way back to the led.
Offline madmonk
« Reply #4 on: May 29, 2018, 12:20:53 pm »
Could you tape the fibre to the inside of the narcell, black insulation tape would provide some light blocking.
Offline Valiant
« Reply #5 on: May 29, 2018, 01:47:47 pm »
Ive heard some mention black tulip before.... Where can i ger it?
« Reply #6 on: May 29, 2018, 03:30:41 pm »
You can get Black Tulip on Amazon, or Michaels, or I think Hobby Lobby.
https://smile.amazon.com/Tulip-41401-Dimensional-Fabric-Paint/dp/B004BQ01CQ/ref=sr_1_30?ie=UTF8&qid=1527625622&sr=8-30&keywords=black+tulip
That would probably be the easiest.  Another option that should (SHOULD) still give you the "bulb" effect is to use the aforementioned SMD, and then a slightly extra dollip of Krystal clear.  I think you can get a a nice rounded bulb effect (both physically and with the light effect).
..but I don't see an issue with the tulip/FO technique if you're more comfotable with that.
Good luck and let us know how it goes!
« Reply #7 on: May 29, 2018, 06:27:12 pm »
Just to add to simi's post. I've seen tulip paint just about everywhere. Even my local Walmart carries it.
Offline Valiant
« Reply #8 on: May 29, 2018, 07:22:22 pm »
So i picked some up.... Question is now, what's the best way to paint them? Open up the bottle and dip them in? Paint one side at a time?
« Reply #9 on: May 30, 2018, 12:56:08 am »
I just tip the bottle over and squeeze it out along the fiber after you have it in place.
It has a super fine tip so it is not that hard.
