Author Topic: Merrittk54's Enterprise 1/350 Refit Build  (Read 1876 times)
Offline Merrittk54
Re: Merrittk54's Enterprise 1/350 Refit Build
« Reply #15 on: September 24, 2018, 03:57:49 pm »
Thanks for the suggestions.  I saw a thread from Neil Smith and he tackled the window situation differently.  I may try to get in touch with him and ask about it.
Pressing on!
-Merrittk54
Offline CrowTRobot
« Reply #16 on: September 25, 2018, 07:23:38 am »
1.  At what point in the build process did you apply the Envirotex? Before or after assembly?  Before or after paint?  Did you have to mask it?
After light-blocking the interior but before assembly & exterior painting. I did have to mask each window, but I used the Orbital Drydock masking set which included pre-cut masks for all the windows.
2.  So the Scotch tape doesn't stick to the cured Envirotex?
Nope! A little tape adhesive remained stuck to some of the windows, but a gentle sanding took care of that. That's another plus: you can sand & polish the resin windows once they're cured.
3.  Did you use this technique on every window (except for the officer's lounge and arboretum, of course)?
Right. For the officer's lounge, arboretum, and rec-deck windows I used very thin sheets of clear styrene. Everything else is resin.
4.  Is it brushed on or poured on?
I "dabbed" it on using a small bit a stretched sprue. I mixed small amounts of resin in a tiny cup and transferred droplets of it into each window using the sprue. This gave me good control over the process. A paint brush or toothpick would be prone to adding air bubbles to the resin. You want to use something smooth to avoid picking up air. I ended up with some bubbles anyway despite my best efforts, but whenever that happened I was able to coax them out using the same bit of stretched sprue.
It's not a quick process, but I think the end results are worth it. The 2-part resin has a finite working time with once it's mixed, so I mixed only small amounts and worked small sections of the model in any given session. For example, in one session I filled the left & right dorsal windows, and in another I did the left & right secondary hull windows. If you break it up this way it makes it more manageable and less tedious.
The only real trouble I had was on the saucer rim windows. If you look at them closely you'll see that the sensor band grooves run right into the window openings. The Scotch tape had a hard time sealing these areas, and as a result some of the resin leaked out into the grooves. I had to clean the cured resin out these areas using scribing tools and gentle sanding.
« Last Edit: September 25, 2018, 09:59:38 am by CrowTRobot »
Offline Merrittk54
« Reply #17 on: September 25, 2018, 09:10:51 am »
Thank you CrowT.
So, when you sand the windows after the resin hardens, I presume they will have an opaque look to them.  Is that what to expect?  Doesn't bother me if they do so long as the light gets through.
Offline CrowTRobot
« Reply #18 on: September 25, 2018, 09:58:05 am »
After sanding with fine-grit paper the windows will have a frosted appearance. You can either polish them or just leave them and let your gloss coat shine them up. Light passes through them easily .
Offline Merrittk54
« Reply #19 on: October 20, 2018, 08:27:30 am »
Hi guys & gals,
Well, it's been a while since my last post.  Life does seem to get in the way of our personal pleasures at times.  Anyway, I have some progress to report to you.  I have pretty much been following Boyd's methodology with my build, plus garnering advice from others such as Crow, neilfsmith and MattA.  And as many, if not all of you have discovered, this kit is not to be trifled with! :P
As you can see, I've done the typical upper saucer prep.  I didn't really have much trouble here.  I did come perilously close to cutting through the saucer with the Dremel in one place; you can see it at the lower left side of the saucer.  I anticipate the there will be a light leak that will need extra blocking.
[/URL]
Adding the photoetch commander's lounge window caused my heartrate to go up at times but I'm very happy with the result.
[/URL]
On the other hand, the bridge was the most challenging for me thus far.  I had no trouble adding the styrene strips to raise the bridge.  The real problems came when I attached the photoetch pieces to the rear bulkhead.  The one on the right did not want to "nest" in its place on the bulkhead.  Is it possible that there is a mold defect on my part?  Several attempts at removing and replacing it started making matters worse, so I did the best I could and moved on.  That piece is slightly raised compared to the left side.  I have since filled in places with plastic putty and shot some primer on it.  I'm happy enough to move on.  I'm thinkimg that this particular imperfection will be one of those that only I and few few other folks (like you!) will know about.
[/URL]
Here's a picture of my new DC power supply.  I've also purchased a new Weller soldering station and will very soon place an order for an airbrush/compressor set.  I'm an aircraft technician by trade but have moved on the the proverbial "desk job".  I've sold some tools and equipment that are no longer needed and used those funds for my new stuff.  LOVE BUYING NEW STUFF!!
[/URL]
I have since light-blocked the saucer and will soon order some LEDs and wiring and really start having fun.  Hope you guys are enjoying your builds.
-Merrittk54
Offline CrowTRobot
« Reply #20 on: October 20, 2018, 05:17:09 pm »
Looking good! The new tools will serve you well in this & future builds.
