Author Topic: 1/350 Refit Base Colour Question  (Read 624 times)
« on: November 13, 2018, 03:24:13 am »
Howdy all!
Although my own refit build is about 6 months away or at least until I finish my MLEV I have just about everything I need with just one exception and that is the white base colour so just putting it out there to see what the rest of you have used so I can start having a look at how much I am going to need and what cost options there are.
Thanks in advance for any reply and ideas.
Offline Merrittk54
Re: 1/350 Refit Base Colour Question
« Reply #1 on: November 13, 2018, 04:56:49 am »
That's a great question.  Do you mean a basecoat on the model to prepare it for the final color?  I'd kinda like to know that as well.
« Reply #2 on: November 13, 2018, 05:34:14 am »
Thanks Merrittk.
I mean the final colour once the kit has been primed and prior to the azteking - for some reason I am assuming it will be Tamiya Flat White but those only come in 10ml (think it's 10ml) jars so something the size of a 1/350 kit is going to use up 10+ at least of those wee jars or that's my thinking anyway.
Offline CrowTRobot
« Reply #3 on: November 13, 2018, 06:23:15 pm »
I used Tamiya Fine White primer in the 180ml spray cans for both primer and finish coats. I think I went through 2 cans.
« Reply #4 on: November 14, 2018, 03:01:24 am »
That's an idea Crow!
Not much room for error with a spray can but certainly an option for me to look at. I could always get a can and practice on the lower hull section that won't be used.
« Reply #5 on: November 14, 2018, 08:06:03 am »
The Tamiya rattle can primers go on very smooth. Definitely worth checking out at least.
« Reply #6 on: November 14, 2018, 09:03:00 am »
Thanks Dave - will definitely give them a lot of consideration nearer build time. Just worried of overspray or "blobby" paint so will need to take my time and be careful.
« Reply #7 on: November 14, 2018, 01:51:51 pm »
I may use the white as the base coat for the top section of my Colonial One. I'm going to do a test between that and the Tamiya flat white in the jar through an airbrush and see which I prefer. I have issues with airbrush blobbiness from time to time so we'll see.
« Reply #8 on: November 14, 2018, 02:10:05 pm »
As I recall Iain, Boyd used to mix and sell custom paints for kits in exact quantities for that particular build....  Something you might also want to ask about?
Offline CrowTRobot
« Reply #9 on: November 14, 2018, 06:44:38 pm »
The aerosol Tamiya primer sprays very nicely, but even if you do end up with blobby rough spots you can sand & polish them out. This stuff took all the drama out of getting a good base color. There will be plenty of drama with the aztecs!
« Reply #10 on: November 15, 2018, 02:32:03 am »
Cheers Crow.
I will get a couple of the bigger cans nearer the time. ;D
Offline madmonk
« Reply #11 on: November 15, 2018, 04:47:25 am »
As an alternative to the Tamiya spray cans Alclad do a white primer that you use with an airbrush.
« Reply #12 on: November 15, 2018, 05:35:36 am »
Unfortunately those paints (don't know if Boyd does them anymore TBH) cannot be imported into the UK.
« Reply #13 on: November 15, 2018, 05:36:50 am »
Did'nt know that TBH so that's another option I can look into. ;D
