Author Topic: RUNABOUT INTERIOR PROJECT  (Read 1304 times)
Offline PCabral
Re: RUNABOUT INTERIOR PROJECT
« Reply #15 on: December 02, 2018, 11:05:55 am »
...parallel to this i'm cover the bulkheads of the crew area walls, and place(temporatelly) the computer console.
The idea is to be transparent to lightly light. the strip on the wall too. in more some days i will  show the closement of the wall base  and its fit with the back window.
« Last Edit: December 02, 2018, 11:12:05 am by PCabral »
Offline PCabral
« Reply #16 on: December 09, 2018, 09:36:01 pm »
More progress on the walls, and the beginning of the bedroom area and the access tower ...
« Last Edit: December 09, 2018, 09:38:14 pm by PCabral »
Offline PCabral
« Reply #17 on: December 09, 2018, 09:42:29 pm »
...and Jefferies tube.
« Last Edit: December 09, 2018, 09:55:05 pm by PCabral »
Offline PCabral
« Reply #18 on: December 09, 2018, 10:12:31 pm »
I used the imagination for this part (because it has no official description of it)
based on the DS9 episode "blaze of glory" where captain cisco enters the jefferies tube.
Remember, many adjustments will still be made. These are not the definitive pieces.
hard work! :)
« Last Edit: December 10, 2018, 09:50:52 am by PCabral »
« Reply #19 on: December 11, 2018, 05:53:39 pm »
Will the hull open up to show all this detail?
Offline PCabral
« Reply #20 on: December 11, 2018, 07:49:13 pm »
Thanks for asking.
Yes I am testing some possibilities. Two are defined: opening the back windows of the ship, as seen in the photos posted, and the opening one of the access doors.
I have another idea, but it is complex and would involve the use of a mechanical gear to open part of the ship (very difficult to perform with small moving parts)
« Last Edit: December 12, 2018, 10:22:21 am by PCabral »
Offline PCabral
« Reply #21 on: December 18, 2018, 10:52:47 pm »
ok, more progress!
Testing the position of the pieces of the front of the ship now, and comparing with the references used in the project.
Many cuts, scraping and sanding at this step before gluing.
« Last Edit: December 18, 2018, 10:59:18 pm by PCabral »
Offline PCabral
« Reply #22 on: December 27, 2018, 08:56:20 am »
More adjustments and positioning of parts. the ceiling was made in 0.05mm sheet, and with the manipulation ended up breaking
and it was necessary to redo with a thickness of 1mm
Offline PCabral
« Reply #23 on: December 27, 2018, 09:20:33 am »
Side walls and hatches
« Reply #24 on: December 27, 2018, 03:36:21 pm »
Coming along nicely!
« Reply #25 on: December 28, 2018, 02:11:47 am »
Looking super detailed.
Offline PCabral
« Reply #26 on: December 29, 2018, 08:26:21 pm »
so far it seems okay.
Offline PCabral
« Reply #27 on: December 29, 2018, 08:41:01 pm »
This will be the new ceiling. it will be removable and with a stronger structure, as I had commented before.
The previous one broke twice. :'(
« Last Edit: December 29, 2018, 08:50:47 pm by PCabral »
Offline PCabral
« Reply #28 on: January 11, 2019, 09:52:53 pm »
All right, the short leave is over! Time to wear the uniform. :)
Offline PCabral
« Reply #29 on: January 15, 2019, 10:55:40 am »
There are some photos of the ceiling.
« Last Edit: January 15, 2019, 01:42:18 pm by PCabral »
